[GRASS-dev] [GRASS GIS] #1883: v.surf.rst gives bad result
trac at osgeo.org
Mon Feb 11 09:11:00 PST 2013
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
running v.surf.rst on grass 70svn on an AMD vishera 8 core 3.5 Ghz cpu
with 8 GB RAM . Fired it up with the defaults for a section of Western
North Carolina with 77 million bare earth points to create a 23 million
cell 20 ft resolution grid. I will attempt to attach screenshots of
completed grid and grid complete with v.surf.bspline. Region was set to
output v.surf.bspline raster.
Complete command sequence below:
GRASS 7.0.svn (ncstpft):~ > v.surf.rst input=nc_1 elevation=nc1_rst_a
Reading features from vector map ...
WARNING: Some points outside of region (ignored)
WARNING: Strip exists with insufficient data
WARNING: There are points outside specified 2D/3D region - 40127 points
ignored
Ignoring 5196048 points (too dense)
Processing segments...
WARNING: Taking too long to find points for interpolation - please change
the region to area where your points are. Continuing
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
G_ludcmp() failed! n=0 d=0.00
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
calculations...
v.surf.rst complete.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1883>
