[GRASS-dev] [GRASS GIS] #1390: fully qualified name on g.mlist
GRASS GIS trac at osgeo.org
Wed Feb 13 15:43:07 PST 2013
 Reporter:  lucadelu     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Default      |     Version:  svn-trunk
 Keywords:  g.mlist      |    Platform:  All
      Cpu:  Unspecified  |
Comment(by hamish):
 again, there are valid arguments on both sides, but one technical reason
 not to use -m by default: it chews up CLI space if you use it like {{{
 g.module input=`g.mlist rast sep=,` }}}, since often you have lots of maps
 but just 4096 chars to describe them in. And when you overflow that the
 error can do odd things (e.g. if the buffer ends right at the end of a map
 name [~10% chance] and it then silently gives you a r.series result for
 the first ~275 days of data instead of 365).
 I'm sure others can think of pulling from the wrong mapset scenarios, I
 guess it's a case of which alternative fails the safest^2 * user demand.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1390#comment:8>
