[GRASS-dev] Bash aliases in GRASS
Glynn Clements
glynn at gclements.plus.com
Sat Feb 16 01:52:34 PST 2013
Nikos Alexandris wrote:
> > #export GISBASE=/opt/grass-7.0.svn
> > export GISBASE=/usr/local/src/grass/svn/dist.x86_64-unknown-linux-gnu
> Shouldn't the following:
> > tmp=/tmp/grass6-"`whoami`"-$GIS_LOCK
> be rather: tmp=/tmp/grass7-"`whoami`"-$GIS_LOCK
The name really doesn't matter. GRASS only ever accesses the file via
the GISRC environment variable.
> > export GISRC="$tmp/gisrc"
> > mkdir "$tmp"
> and the following:
> > cp ~/.grassrc6 "$GISRC"
> be rather: cp ~/.grass7/rc "$GISRC"
Again, it doesn't actually matter unless the same file is supposed to
be used when creating a GRASS session via the startup script.
FWIW, I do have a ~/.grass7/rc file; the timestamp is Feb 2010, which
shows how often I run the startup script.
