[GRASS-dev] GRASS GIS nightly builds
Rashad M
mohammedrashadkm at gmail.com
Sat Feb 16 02:01:35 PST 2013
btw, grass64 is fine
On Sat, Feb 16, 2013 at 3:30 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> I am updating the version number it was like this:
> package name: grass70
> version 7.2
> martinL pointed out the version problem and now changing to this:
> version 7.0
> I need to make some more modification to make this work
> with previous version i had daily updates but version mismatch is a
> serious issue
> sorry for the incovenience
> On Sat, Feb 16, 2013 at 2:59 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Sun, Jan 13, 2013 at 2:37 PM, Rashad M <mohammedrashadkm at gmail.com>
>> wrote:
>> > I had tested the ppa packages on ubuntu precise and there seems to have
>> some
>> > issues
>> > 1. grass startup script not working
>> I have checked
>> https://launchpadlibrarian.net/131311585/buildlog_ubuntu-precise-amd64.grass7_7.0-1~svn55042~ubuntu3_FAILEDTOBUILD.txt.gz
>> and seen this:
>> cp /build/buildd/grass7-7.0/debian/xgrass7
>> /build/buildd/grass7-7.0/debian/grass7/usr/bin/grass70
>> cp: cannot create regular file
>> `/build/buildd/grass7-7.0/debian/grass7/usr/bin/grass70': No such file
>> or directory
>> make: *** [install] Error 1
>> Perhaps just the name is a bit different? Above I see a line
>> make[5]:
>> `/build/buildd/grass7-7.0/dist.x86_64-pc-linux-gnu/docs/man/man1/grass7.1'
>> is up to date.
>> so the start script maybe "grass7.1" rather than grass70 (as it should
>> ideally be).
>> Markus
> Regards,
> Rashad
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130216/bccb15dd/attachment.html>
