[GRASS-dev] GRASS GIS nightly builds
Rashad M mohammedrashadkm at gmail.com
Sat Feb 23 10:29:15 PST 2013
Hi Markus,
grass70 built is available in ubuntugis-testing[1]. I will maintain daily
updates depending on the changes in svn. package name issue is also
resolved now
package name: grass70
version: 7.0
On Sat, Feb 16, 2013 at 3:31 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> btw, grass64 is fine
> On Sat, Feb 16, 2013 at 3:30 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>> I am updating the version number it was like this:
>> version 7.2
>> martinL pointed out the version problem and now  changing to this:
>> version 7.0
>> I need to make some more modification to make this work
>> with previous version i had daily updates but version mismatch is a
>> serious issue
>> sorry for the incovenience
>> On Sat, Feb 16, 2013 at 2:59 AM, Markus Neteler <neteler at osgeo.org>wrote:
>>> On Sun, Jan 13, 2013 at 2:37 PM, Rashad M <mohammedrashadkm at gmail.com>
>>> wrote:
>>> > I had tested the ppa packages on ubuntu precise and there seems to
>>> have some
>>> > issues
>>> > 1. grass startup script not working
>>> I have checked
>>> https://launchpadlibrarian.net/131311585/buildlog_ubuntu-precise-amd64.grass7_7.0-1~svn55042~ubuntu3_FAILEDTOBUILD.txt.gz
>>> and seen this:
>>> cp /build/buildd/grass7-7.0/debian/xgrass7
>>> /build/buildd/grass7-7.0/debian/grass7/usr/bin/grass70
>>> cp: cannot create regular file
>>> `/build/buildd/grass7-7.0/debian/grass7/usr/bin/grass70': No such file
>>> or directory
>>> make: *** [install] Error 1
>>> Perhaps just the name is a bit different? Above I see a line
>>> make[5]:
>>> `/build/buildd/grass7-7.0/dist.x86_64-pc-linux-gnu/docs/man/man1/grass7.1'
>>> is up to date.
>>> so the start script maybe "grass7.1" rather than grass70 (as it should
>>> ideally be).
>>> Markus
>> Regards,
>>    Rashad
> Regards,
>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130223/882f78e4/attachment-0001.html>
