[GRASS-dev] Additional switch(es) for <g.mapsets>?
Nikos Alexandris nik at nikosalexandris.net
Fri Feb 15 23:38:42 PST 2013
Hi devs!
Would you consider adding an optional "-r" (as "remove") switch to the
<g.mapsets> module?
Or, add an optional switch "-s" or "-x" (as "select-ive/-ed" or as
"exclusive") which will add the specified mapsets (parameter "mapset=") and
remove the rest (but the current, of course)?
Justification
I work with Landsat imagery, many tiles, imported in individual Mapsets (per
Landsat scene) and I often want to run/loop over many Mapsets.  I require to
ensure that, while loopen over Mapsets (=individual Landsat scenes) and,
working on each of the bands that pertain to a Landsat scene, raster
processing modules wont touch any bands out of the current Mapset. Even avoid
WARNING mesages that a raster map A has been found elsewhere, but the raster
map B in Mapset B will be used.
A use case is, for example, that I need to selectively use  i.landsat.toar  on
many Mapsets (that is, on many Landsat scenes) with the default
method(=uncorrected) and produce At-Sensor-Reflectances while performing
conversion to Top-of-Atmosphere Radiance with  i.landsat.toar's  "-r" switch.
Currently, in bash-scripting G7, I try first to remove access to all mapsets
but the current (of course) as follows:
# one-liner!
g.mapsets mapset=$(g.mapsets -p sep=newline | grep -v `g.mapset -p` | tr "\n"
",") operation=remove
Then, I selectively (and manually) add mapsets of interest.
Thank you, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130216/f29db3a3/attachment-0001.pgp>
