[GRASS-dev] r.fillnulls error <z> is not a valid flag (grass7)
epi massimodisasha at gmail.com
Sun Feb 17 07:41:18 PST 2013
Hi ,
i was trying to fill some null values on a DTM but i got this error :
GRASS 7.0.svn (utm19N_wgs84):~ > r.fillnulls input=stell_na10m output=stell10m --overwrite
Using RST interpolation...
Locating and isolating NULL areas...
 100%
Growing NULL areas
Assigning IDs to NULL areas
 100%
Processing 171 map holes
Filling hole 1 of 171
 100%
 100%
 100%
Note: The following warnings about number of points for interpolation may
be ignored.
ERROR: Sorry, <z> is not a valid flag
ERROR: Failed to fill hole 1
WARNING: Raster map <r_fillnulls_82080_hole_1_dem> not found
WARNING: <r_fillnulls_82080_hole_1_dem> nothing removed
the raster is :
GRASS 7.0.svn (utm19N_wgs84):~ > g.region rast=stell_na10m -ap
projection: 1 (UTM)
zone:       19
datum:      wgs84
ellipsoid:  wgs84
north:      4740344.78303
south:      4659553.88889
west:       342858.421078
east:       415502.090519
nsres:      10.00011067
ewres:      10.00050515
rows:       8079
cols:       7264
cells:      58685856
epi:~ epi$ cd /usr/local/src/grass_trunk/
epi:grass_trunk epi$ svn info
Path: .
URL: https://svn.osgeo.org/grass/grass/trunk
Repository Root: https://svn.osgeo.org/grass
Repository UUID: 15284696-431f-4ddb-bdfa-cd5b030d7da7
Revision: 55083
Node Kind: directory
Schedule: normal
Last Changed Author: martinl
Last Changed Rev: 55083
Last Changed Date: 2013-02-17 08:03:46 -0500 (Sun, 17 Feb 2013)
Have you any clue on what's going wrong ?
i'll try with grass6 to see if it is a problem with trunk.
Thanks,
Massimo.
