[GRASS-dev] Additional switch(es) for <g.mapsets>?
Hamish hamish_b at yahoo.com
Sun Feb 17 13:33:25 PST 2013
Hamish:
> > ps- should failure to include PERMANENT in a new search path
> > produce a warning G_message()? (hushed by --quiet)
Nikos:
> you mean in case of "mapset=WhatEverMapset,PERMANENT op=set",
> right?
no, when you use op=set the entire mapset search list is replaced
in full, so "mapset=WhatEverMapset op=set" removes PERMANENT
from the search list, which while possible, isn't usually the
expected behaviour.
Hamish
