[GRASS-dev] [GRASS GIS] #1888: r.terraflow won't run
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Feb 19 03:56:15 PST 2013
Hi Anna,
I am not sure what you mean with 'special case'? The error message appears
when I try to open the r.terraflow gui, i.e., before I can set any value.
Just to add, it works for me in GRASS 6.4 (running it right now), so I
would assume it has something to do how this is implemented in GRASS 7.0?
Cheers,
Paulo
> Reporter: pvanbosgeo | Owner: grass-dev@…
> Type: defect | Status: new
> Priority: normal | Milestone: 7.0.0
> Component: wxGUI | Version: svn-trunk
> Keywords: r.terraflow, forms | Platform: Unspecified
> Cpu: Unspecified |
> Comment(by annakrat):
> The problem is that r.terraflow option ''d8cut'' has default value
> 'infinity'. The gui expects float and not string. Inside r.terraflow
> answer infinity means
> static const flowaccumulation_type MAX_ACCU = 1e+15;
> I am not sure how to handle this special case. We can test 'infinity'
> string and set maximum value of the Float Spin instead (which is currently
> 1e9, but it can be increased).
> Anna
> Ticket URL: <http://trac.osgeo.org/grass/ticket/1888#comment:2>
> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130219/efe10601/attachment.html>
