[GRASS-dev] [GRASS GIS] #1888: r.terraflow won't run
Anna Kratochvílová
kratochanna at gmail.com
Tue Feb 19 04:07:37 PST 2013
On Tue, Feb 19, 2013 at 12:56 PM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hi Anna,
> I am not sure what you mean with 'special case'? The error message appears
> when I try to open the r.terraflow gui, i.e., before I can set any value.
With the special case I mean the default value 'infinity' when the
option is defined as TYPE_DOUBLE
> Just to add, it works for me in GRASS 6.4 (running it right now), so I would
> assume it has something to do how this is implemented in GRASS 7.0?
The difference is that in 6.4 we use TextCtrl in dialogs for float
values, but in 7 it was changed to use FloatSpin control (see for
example d.vect symbol size option). So text 'infinity' is completely
ok for TextCtrl but not for a control expecting numbers.
I don't know, maybe we should go back and use the TextCtrl widget?
> Cheers,
> Paulo
>> Reporter: pvanbosgeo | Owner: grass-dev@…
>> Type: defect | Status: new
>> Priority: normal | Milestone: 7.0.0
>> Component: wxGUI | Version: svn-trunk
>> Keywords: r.terraflow, forms | Platform: Unspecified
>> Cpu: Unspecified |
>> Comment(by annakrat):
>> The problem is that r.terraflow option ''d8cut'' has default value
>> 'infinity'. The gui expects float and not string. Inside r.terraflow
>> answer infinity means
>> static const flowaccumulation_type MAX_ACCU = 1e+15;
>> I am not sure how to handle this special case. We can test 'infinity'
>> string and set maximum value of the Float Spin instead (which is
>> currently
>> 1e9, but it can be increased).
>> Anna
>> Ticket URL: <http://trac.osgeo.org/grass/ticket/1888#comment:2>
>> GRASS GIS <http://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
