[GRASS-dev] [GRASS GIS] #1888: r.terraflow won't run
Martin Landa landa.martin at gmail.com
Tue Feb 19 04:14:36 PST 2013
2013/2/19 Martin Landa <landa.martin at gmail.com>:
> not a number then use TextCtrl instead of FloatSpin. Or to change
> default answer in r.terraflow to a number.
or probably in the best case to remove default answer, eg.
        d8cut   Routing using SFD (D8) direction
                  If flow accumulation is larger than this value it is
routed using SFD (D8) direction (meaningfull only  for MFD flow). *If
not give, the use infinity.*
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
