[GRASS-dev] [GRASS GIS] #1888: r.terraflow won't run
Anna Kratochvílová
kratochanna at gmail.com
Tue Feb 19 04:19:17 PST 2013
On Tue, Feb 19, 2013 at 1:14 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2013/2/19 Martin Landa <landa.martin at gmail.com>:
>> not a number then use TextCtrl instead of FloatSpin. Or to change
>> default answer in r.terraflow to a number.
> or probably in the best case to remove default answer, eg.
> d8cut Routing using SFD (D8) direction
> If flow accumulation is larger than this value it is
> routed using SFD (D8) direction (meaningfull only for MFD flow). *If
> not give, the use infinity.*
I agree with this solution.
Anna
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
