[GRASS-dev] [GRASS GIS] #1888: r.terraflow won't run
Martin Landa landa.martin at gmail.com
Tue Feb 19 04:26:17 PST 2013
2013/2/19 Anna Kratochvílová <kratochanna at gmail.com>:
>> or probably in the best case to remove default answer, eg.
>>         d8cut   Routing using SFD (D8) direction
>>                   If flow accumulation is larger than this value it is
>> routed using SFD (D8) direction (meaningfull only  for MFD flow). *If
>> not give, the use infinity.*
> I agree with this solution.
done in r55119. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
