[GRASS-dev] On (Landsat) imagery naming patterns
Nikos Alexandris nik at nikosalexandris.net
Fri Feb 22 01:49:12 PST 2013
Jorge:
> Hi, I quick review the code of i.landsat.* and the programms never use
> the dot as a part of the output filenames.
> The output names are construct as prefix+suffix not as
> prefix+'.'+suffix. Then, the question is more on 'style' than on
> programmation. The only change needed are in the HTML when a decission
> is taken.
Right!
( I also wrote in the beginning:
Nikos A:
> In addition,  the respective manuals for modules like <i.landsat.toar>,
> <i.landsat.acca>, <i.topo.corr> hold in their examples/descriptions (thus,
> someone can easily interpret that these modules "encourage" the use of)
> names like "B.", "B.toar", "toar.5", et.c.
It's just that people will likely use what the manuals suggest!
> Another quick question: What is the better name to the Landsat 8? tm8 or
> ot8 (from OLI/TIRS 8).
If my view counts a small little bit:  "tm8" rings a bell like "thematic
mapper" which is maybe a bit confusing.
> I used ot8 in the previous version send to Nikos
> but before send to Markus it could be changed.
Sorry Jorge, don't have the time to test it now.
Thank you once again for your efforts Jorge :-)
Best, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130222/b1e56453/attachment.pgp>
