[GRASS-dev] [GRASS GIS] #1829: Allow user to override MAPSET ownership check
GRASS GIS trac at osgeo.org
Fri Feb 22 03:06:23 PST 2013
  Reporter:  marisn       |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  minor        |   Milestone:  7.0.0
 Component:  Startup      |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:6 glynn]:
 > Replying to [comment:2 wenzeslaus]:
 > > However, I don't know how to support this in GUI.
 > I'm not sure you should support it in the GUI. It should be set on
 single-user systems, and unset on multi-user systems. On a given system,
 there's no reason for the user to change it.
 OK, because there is no need to set it from GUI and the programmer's way
 is available, I'm closing the ticked as fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1829#comment:7>
