[GRASS-dev] attribute manager "read only mode"
Luca Delucchi lucadeluge at gmail.com
Fri Feb 22 06:41:39 PST 2013
Hi devs,
just finished a course on windows XP using GRASS 6.4 downloadable from
Martin server [0] (I downloaded WinGRASS-6.4.3svn-r55116-507-Setup.exe
). I found a really ugly problem: the attribute manager was not able
to change any tables because it reported that the table was in "read
only mode".
But using command as v.db.join the students were able to join to
different table. I tested it in more then 10 machine.
Someone else could report this problem?
[0] http://wingrass.fsv.cvut.cz/grass64/
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
