[GRASS-dev] attribute manager "read only mode"
Martin Landa landa.martin at gmail.com
Fri Feb 22 06:50:05 PST 2013
2013/2/22 Luca Delucchi <lucadeluge at gmail.com>:
> ). I found a really ugly problem: the attribute manager was not able
> to change any tables because it reported that the table was in "read
> only mode".
> But using command as v.db.join the students were able to join to
> different table. I tested it in more then 10 machine.
> Someone else could report this problem?
see r55106 [1]. Martin
[1] http://trac.osgeo.org/grass/changeset/55106
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
