[GRASS-dev] [GRASS GIS] #1897: grass7 wxgui query: allow copying individual elements from query results
trac at osgeo.org
Mon Feb 25 08:28:19 PST 2013
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: query | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [ticket:1897 mlennert]:
> In the current implementation of map querying in the grass7 wxgui, when
you click on the display a dedicated window ("Query results") opens with
the r/v.what results. One can copy the complete window contents to the
clipboard, but not individual elements.
This is a limitation of wxPython. There are a few possibilities what to
do:
* on right click show context menu with 'copy selected value'
* add checkbox 'show query results also in command console'
* let the user choose in preferences if to use the dialog or not (use
command console)
> Linked to that one might also question the need of the dedicated display
window. Why not simply continue to use the console output ?
The dialog has some advantages:
* dialog is more natural for new and not advanced users
* the results are better organized, for example the output of raster
querying for more maps is a mess (but I understand that this argument is
more about the formatting than using dialog)
* dialog uses tree structure, so you can hide some results
Regards,
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1897#comment:1>
