[GRASS-dev] [GRASS GIS] #1897: grass7 wxgui query: allow copying individual elements from query results
GRASS GIS trac at osgeo.org
Mon Feb 25 04:50:54 PST 2013
 Reporter:  mlennert     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  query        |    Platform:  Unspecified
      Cpu:  Unspecified  |
 In the current implementation of map querying in the grass7 wxgui, when
 you click on the display a dedicated window ("Query results") opens with
 the r/v.what results. One can copy the complete window contents to the
 clipboard, but not individual elements.
 This makes working with these results a bit tedious as if you need a
 specific element you have to copy the entire contents of the window to a
 text editor to then be able to copy just what you need.
 It would be much more practical IMHO to be able to directly select and
 copy individual elements.
 Linked to that one might also question the need of the dedicated display
 window. Why not simply continue to use the console output ?
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1897>
