[GRASS-dev] [GRASS GIS] #1606: WXGUI regression - attribute query tool reports "nothing found" when clicking on a vector object
GRASS GIS trac at osgeo.org
Mon Feb 25 04:44:24 PST 2013
  Reporter:  marisn       |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  blocker      |   Milestone:  6.4.3
 Component:  wxGUI        |     Version:  6.4.3 RCs
Resolution:               |    Keywords:  query
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by mlennert):
 Replying to [comment:13 annakrat]:
 > Replying to [comment:12 mlennert]:
 > > Replying to [comment:11 annakrat]:
 > > > In case there exist layers of vector map which are not connected to
 db, the query output is redirected in command console (r55184). This is
 the easiest solution, other solutions would need more changes which means
 more possible errors.
 > > Thanks ! It would be great, however, to be able to copy directly from
 the display, instead of having to copy everything to the clipboard, copy
 that to a text editor and then pick out the elements you want. As an
 example: sometimes I just want to identify the coordinates of a place. It
 would be nice to be able to click on it and then directly copy the values
 for easting and northing from the query results window.
 > You are talking about new querying in grass7?
 Yes, sorry. I got confused between versions here. The grass6 solution also
 works well, by the way. I'm just afraid that it will be a bit confusing
 for users to see two different reactions to the same action (either
 editable attributes or output to console).
 > It is different than in grass 64, it is more consistent. But needs some
 improvemnets. Could you create a ticket for this? As for the coordinates,
 you can get them by right click on the map display.
 Thanks for the tip on coordinates (hadn't noticed this, yet, it's very
 practical !), but my remark was more general. I'll file a ticket.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1606#comment:14>
