[GRASS-dev] [GRASS GIS] #1606: WXGUI regression - attribute query tool reports "nothing found" when clicking on a vector object
trac at osgeo.org
Mon Feb 25 04:34:19 PST 2013
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.3 RCs
Resolution: | Keywords: query
Platform: Unspecified | Cpu: Unspecified
Comment(by annakrat):
Replying to [comment:12 mlennert]:
> Replying to [comment:11 annakrat]:
> > In case there exist layers of vector map which are not connected to
db, the query output is redirected in command console (r55184). This is
the easiest solution, other solutions would need more changes which means
more possible errors.
> Thanks ! It would be great, however, to be able to copy directly from
the display, instead of having to copy everything to the clipboard, copy
that to a text editor and then pick out the elements you want. As an
example: sometimes I just want to identify the coordinates of a place. It
would be nice to be able to click on it and then directly copy the values
for easting and northing from the query results window.
You are talking about new querying in grass7? It is different than in
grass 64, it is more consistent. But needs some improvemnets. Could you
create a ticket for this? As for the coordinates, you can get them by
right click on the map display.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1606#comment:13>
