[GRASS-dev] Python module gui inputs
Eric Goddard
egoddard1010 at gmail.com
Wed Feb 27 14:05:59 PST 2013
Hi all,
This is my first foray into grass scripting. I'm working on a GRASS 7
python module to create a local relief model from a lidar derived
surface. The code works, but for some reason in the auto generated gui
for the tool, the field to enter a neighborhood size to use for the
low pass filter doesn't appear. my module code is below. Any
assistance would be greatly appreciated.
Thanks,
Eric
#%module
#% description: Creates a Local Relief Model from input raster.
#% keywords: lrm
#% keywords: lidar
#% overwrite: yes
#%end
#%option G_OPT_R_INPUT
#% key:input_map
#% description: Select input raster
#% required: yes
#%end
#%option
#% key: output_map
#% type: string
#% description: Name for output LRM raster
#% required: yes
#%end
#%option
#% key: neighbor_size
#% type: double
#% description: The neighborhood size to be used in the low pass
filter. Default is 25.
#% required: no
#% answer: 25
#%end
