[GRASS-dev] Python module gui inputs
Eric Goddard egoddard1010 at gmail.com
Wed Feb 27 16:03:59 PST 2013
Thanks for the response, Luca. I've made the change to the output
option, but the neighbor_size option still isn't appearing in the gui.
The descriptions will become more verbose once the code and everything
is working; what is in the script now is just the bare minimum for it
to run. and generate a gui. I've pasted the full code at
http://pastebin.com/4PCJ0xeG.
On Wed, Feb 27, 2013 at 4:46 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> 2013/2/27 Eric Goddard <egoddard1010 at gmail.com>:
>> Hi all,
> Hi Eric,
>> Thanks,
>> Eric
>> #%module
>> #%  description: Creates a Local Relief Model from input raster.
>> #%  keywords: lrm
>> #%  keywords: lidar
>> #%  overwrite: yes
>> #%end
>> #%option G_OPT_R_INPUT
>> #%  key:input_map
>> #%  description: Select input raster
>> #%  required: yes
>> #%end
>> #%option
>> #%  key: output_map
>> #%  type: string
>> #%  description: Name for output LRM raster
>> #%  required: yes
>> #%end
>> #%option
>> #%  key: neighbor_size
>> #%  type: double
>> #%  description: The neighborhood size to be used in the low pass
>> filter. Default is 25.
>> #%  required: no
>> #%  answer: 25
>> #%end
> I would like to change the description of module as following, for a
> more compliant GRASS description.
> I think this should work. Otherwise could you paste you entire code
> (better in a external site as pastebin)
> #%module
> #% keywords: lrm
> #% keywords: lidar
> #% overwrite: yes
> #%end
> #%end
> #%option G_OPT_R_OUTPUT
> #%end
> #%option
> #% type: double
> #% required: no
> #% answer: 25
> #%end
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
