[GRASS-dev] Python module gui inputs
Vaclav Petras wenzeslaus at gmail.com
Thu Feb 28 01:03:37 PST 2013
Hi Eric, for me it works (with code from paste bin). GUI shows and
neighbor_size is in the Optional tab.
Another suggestions about options: If the "description" is long, you
can use "label" which will be shown in the gui and description will
become a tooltip. There is usually no need to write default value into
the description since default value is already in the gui or in
y.our.module --help.
I'm afraid that the programming manual does not list these practices.
http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing
Vaclav
On 28 February 2013 01:03, Eric Goddard <egoddard1010 at gmail.com> wrote:
> Thanks for the response, Luca. I've made the change to the output
> option, but the neighbor_size option still isn't appearing in the gui.
> The descriptions will become more verbose once the code and everything
> is working; what is in the script now is just the bare minimum for it
> to run. and generate a gui. I've pasted the full code at
> http://pastebin.com/4PCJ0xeG.
> On Wed, Feb 27, 2013 at 4:46 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> 2013/2/27 Eric Goddard <egoddard1010 at gmail.com>:
>>> Hi all,
>> Hi Eric,
>>> Thanks,
>>> Eric
>>> #%module
>>> #%  description: Creates a Local Relief Model from input raster.
>>> #%  keywords: lrm
>>> #%  keywords: lidar
>>> #%  overwrite: yes
>>> #%end
>>> #%option G_OPT_R_INPUT
>>> #%  key:input_map
>>> #%  description: Select input raster
>>> #%  required: yes
>>> #%end
>>> #%option
>>> #%  key: output_map
>>> #%  type: string
>>> #%  description: Name for output LRM raster
>>> #%  required: yes
>>> #%end
>>> #%option
>>> #%  key: neighbor_size
>>> #%  type: double
>>> #%  description: The neighborhood size to be used in the low pass
>>> filter. Default is 25.
>>> #%  required: no
>>> #%  answer: 25
>>> #%end
>> I would like to change the description of module as following, for a
>> more compliant GRASS description.
>> I think this should work. Otherwise could you paste you entire code
>> (better in a external site as pastebin)
>> #%module
>> #% keywords: lrm
>> #% keywords: lidar
>> #% overwrite: yes
>> #%end
>> #%end
>> #%option G_OPT_R_OUTPUT
>> #%end
>> #%option
>> #% type: double
>> #% required: no
>> #% answer: 25
>> #%end
>> ciao
>> Luca
>> http://gis.cri.fmach.it/delucchi/
>> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
