[GRASS-dev] release planning and no volume display on Mac - Any info on where crash happens?
Helena Mitasova hmitaso at ncsu.edu
Fri Jan 11 12:18:31 PST 2013
On Jan 11, 2013, at 2:48 PM, Anna Kratochvílová wrote:
> Hi Michael,
> On Mon, Jan 7, 2013 at 7:57 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> So I found a change that would make volumes visible again a week ago. Anyone have any thoughts about this? Do we need the function/procedure that sets the memory pointer for volume displays? Or can we simply get rid of it? Is it needed for Linux? Windows? Any thoughts about what happens without it?
> I can confirm that removing those two lines does no harm for me
> (Linux). However it's clear that we cannot just leave them out without
> understanding why they are there. Can anyone (for example Glynn) think
> of a reason why this code is crashing on Mac and not on Linux (no idea
> about Windows)?
I just tested it on Windows 7 with WinGRASS6.4.3RC2 and I am happy to report that it works OK
 - both isosurfaces and crossections.
However, in the same WinGRASS6.4.3.RC2 there is a problem with the path to cellheader in G3d_read_window,
so r3.info and g.region rast3d=myvoxel gives an error that the region is invalid.
Also, I finally got a laptop with MacOSX10.8 and I can confirm that in GRASS6.4.3RC2 binary
posted Michael isusrfaces crash wxGUI. I will try to compile myself but I expect the result
to be the same given that it crashed for William as well.
Helena
> And why removing of realloc helps?
> Regards,
> Anna
>> Cheers
>> Michael
>> ____________________
>> C. Michael Barton
>> Director, Center for Social Dynamics & Complexity
>> Professor of Anthropology, School of Human Evolution & Social Change
>> Arizona State University
>> voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
>> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On Jan 2, 2013, at 11:22 PM, Michael Barton <michael.barton at asu.edu> wrote:
>>> GREAT NEWS!
>>> Commenting out both gvl_align_data lines (#684 and #1009) in gvl_calc_c makes this work. Both slices and isosurfaces display and do not crash. I don't know if there would be a problem with larger files or not. But this is finally functional again.
>>> BUT the command you sent does NOT work. It gives a segmentation fault error:
>>> m.nviz.image elevation_map=JR_2008_ALL_dem at test3d -a mode=fine resolution_fine=6 color_map=JR_2008_ALL_dem at test3d volume=jr_7408MR_2m_t70 at test3d volume_shading=gouraud volume_resolution=1 volume_position=0,0,20 isosurf_level=1:18.0 isosurf_color_map=jr_7408MR_2m_t70 at test3d isosurf_transparency_value=0 slice=1:x,1:z slice_position=0.000000,1.000000,0.520000,1.000000,0.000000,1.000000,0.250000,0.720000,0.080000,1.000000,0.000000,1.000000 slice_transparency=0,0 position=0.84,0.16 height=356 perspective=20 twist=0 zexag=5.000000 focus=569,593,28 light_position=0.68,0.68,0.80 light_brightness=80 light_ambient=20 light_color=255:255:255 output=jrvoltest format=tif size=798,545
>>> Loading raster map <JR_2008_ALL_dem at test3d>...
>>> 100%
>>> 100%
>>> Translating colors from raster map <JR_2008_ALL_dem at test3d>...
>>> 100%
>>> Loading 3d raster map <jr_7408MR_2m_t70 at test3d>...
>>> Segmentation fault: 11
>>> Also, somewhere there is a bug somewhere that is sending progress bar text to the screen for any nviz activity (GRASS_INFO_PERCENT: 0...)
>>> So now we have some kind of workaround. I don't know if there are any other down sides to bypassing this memory reallocation, but this is a good start on fixing this finally. Thanks Anna and Helena.
>>> Michael
>>> C. Michael Barton
>>> On Jan 2, 2013, at 10:45 PM, Helena Mitasova <hmitaso at ncsu.edu>
>>> wrote:
>>>> Michael,
>>>> what you describe sounds as if you had only one depth layer so let us check first that the 3D region is right.
>>>> If the 3d region is set to the provided 3d raster given here
>>>> http://skagit.meas.ncsu.edu/~helena/grasswork/JR_7408MR_2m_t70.asci
>>>> http://skagit.meas.ncsu.edu/~helena/grasswork/JR_2008_ALL.asci (reference 2d raster)
>>>> it should look like this
>>>> GRASS 6.4.3svn (nc_spm_05):~ > g.region -p3
>>>> projection: 99 (Lambert Conformal Conic)
>>>> zone:       0
>>>> datum:      nad83
>>>> ellipsoid:  a=6378137 es=0.006694380022900787
>>>> north:      250690
>>>> south:      249502
>>>> west:       912791
>>>> east:       913931
>>>> top:        64.00000000
>>>> bottom:     0.00000000
>>>> nsres:      2
>>>> nsres3:     2
>>>> ewres:      2
>>>> ewres3:     2
>>>> tbres:      8
>>>> rows:       594
>>>> rows3:      594
>>>> cols:       570
>>>> cols3:      570
>>>> depths:     8
>>>> can you then try to run the following command (please adjust the names of the 2d and 3d rasters to your actual names)
>>>> m.nviz.image elevation_map=JR_2008_ALL at Baseline_JR -a mode=fine resolution_fine=6 color_map=JR_2008_ALL at Baseline_JR \
>>>> volume=JR_7408MR_2m_t70 at Baseline_JR volume_shading=gouraud volume_resolution=1 volume_position=0,0,20 isosurf_level=1:18.0 isosurf_color_map=JR_7408MR_2m_t70 at Baseline_JR isosurf_transparency_value=0 slice=1:x,1:z slice_position=0.000000,1.000000,0.520000,1.000000,0.000000,1.000000,0.250000,0.720000,0.080000,1.000000,0.000000,1.000000 slice_transparency=0,0 position=0.84,0.16 height=356 perspective=20 twist=0 zexag=5.000000 focus=569,593,28 \
>>>> light_position=0.68,0.68,0.80 light_brightness=80 light_ambient=20 light_color=255:255:255 \
>>>> it should generate an image with isosurfaces and a tilted crossection - it is not quite what I have on the screen, because
>>>> it apparently uses some default values instead of actual values (e.g. for toggle normal direction and crossection) but it should have some
>>>> isosurfaces. Let us know whether the command line works and we can go from there.
>>>> Helena
>>>> On Jan 3, 2013, at 12:08 AM, Michael Barton wrote:
>>>>> When I put in values between 15 and 20 I can see the horizontal outline of a rectangle but not the 3D shape of a box. No isosurfaces display. No crash either.
>>>>> I un-commented line 684 and commented line 1009 in gvl_calc_c to see what happens to slices
>>>>> /* gvl_align_data(pos, slice->data); */
>>>>> A horizontal slice displays and I can manipulate it in the X and Y direction. But I cannot manipulate it in the Z direction. Also, a Z dimension slice shows up only as a line. Also, isosurfaces do not display. But there is no crash for either isosurfaces or slices when I comment out this line. On the face of it, a memory issue related to display in the Z dimension is causing a crash. Commenting out calls to gvl_align_data in gvl_calc_c stops the crash and stops display in the Z dimension. There is also something called gvl_calc2_c in this folder. Its code is very similar to gvl_calc_c
>>>>> I'm guessing that Martin and Helena know the most about the relevant C code for lib/ogsf/*. Glynn may have some insight into this too. Anyone else is welcome to chime in.
>>>>> FWIW, the last time gvl_calc_c was touched was by Glynn 4 years ago (glynn: Fix char/char* mismatch (merge from trunk, r32757)).
>>>>> Volume display worked as recently as fall 2011 AFAIK.
>>>>> Michael
>>>>> C. Michael Barton
>>>>> On Jan 2, 2013, at 10:21 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
>>>>>> On Jan 2, 2013, at 1:34 AM, Michael Barton wrote:
>>>>>>> Testing with GRASS 6.4.3RC2
>>>>>>> Rem-ing out line 684 in gvl_calc_c
>>>>>>> /* gvl_align_data(dbuff[i].ndx_new, dbuff[i].new); */
>>>>>>> prevents crashing. But I don't see an isosurface.
>>>>>>> Helena,
>>>>>>> I'm using your test data (jr_7408MR_2m_t70)
>>>>>>> What is a good value to set for an isosurface to see anything?
>>>>>> anything between 15 to 20 should work.
>>>>>> You can move the volume a little bit above the surface to see the entire isosurface
>>>>>> Here is an example of settings that I have used (the name of the volume raster is slightly different
>>>>>> but it is the same data).
>>>>>>> m.nviz.image elevation_map=JR_2008_ALL -a mode=fine resolution_fine=1 color=243:243:243 volume=JR_7408MR_2m volume_shading=gouraud volume_resolution=1 volume_position=0,0,20 isosurf_level=1:17.0 isosurf_color_map=JR_7408MR_2m isosurf_transp_value=0 position=0.11,0.07 height=243 perspective=13 twist=0 zexag=6.000000 focus=569,593,17 light_position=0.26,-0.30,0.61 light_brightness=94 light_ambient=55 light_color=255:255:255 output=nviz_output format=ppm size=798,545
>>>>>> This volume includes no-data because the original rasters were masked, I think it would be useful to start with a volume without no-data -
>>>>>> just use r3.null to replace no-data with 0.
>>>>>> Let me know if it would be useful for me to run same thing in MacOSX 10.6 (I still don't have 10.8 machine quite ready),
>>>>>> (see the slides 12 and 13 here for the isosurfaces at different levels, I have the isosurfaces colored by year - I don't think I gave you
>>>>>> that raster, so your isosurfaces should be just a single color).
>>>>>> http://skagit.meas.ncsu.edu/~helena/publwork/AGU2012lidar6.pptx
>>>>>> Helena
>>>>>>> Slices still crash because they still call gvl_align_data. As before, though initially displaying a slice works fine. It only crashes when I try to change something about the slice and it wants to redraw.
>>>>>>> Michael
>>>>>>> C. Michael Barton
>>>>>>> On Jan 1, 2013, at 1:24 PM, Anna Kratochvílová <kratochanna at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi Michael,
>>>>>>>> On Tue, Jan 1, 2013 at 8:48 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>>>>>>> Hi Anna,
>>>>>>>>> On the slim chance that you are online today, can you tell me where gvl_align_data in gvl_calc.c reside in either the source code or compiled code? I have a bit of down time and thought I'd see what I could find out about the volume display breaking. I don't know C but can selectively rem out some things and see what happens.
>>>>>>>> It should be here
>>>>>>>> http://trac.osgeo.org/grass/browser/grass/trunk/lib/ogsf/gvl_calc.c#L685
>>>>>>>> Also, you could try debugging with QtCreator [1] (as an user-friendly
>>>>>>>> interface to the debugger), it is quite easy, here [2] is some help
>>>>>>>> for setting up the project. I don't know what method you would like to
>>>>>>>> use but this is the easiest I know. I suppose it should work on Mac,
>>>>>>>> too.
>>>>>>>> Regards,
>>>>>>>> Anna
>>>>>>>> [1] http://qt-project.org/downloads
>>>>>>>> [2] http://grasswiki.osgeo.org/wiki/Using_QtCreator_for_GRASS_C_development#Debugging
>>>>>>>>> Thanks
>>>>>>>>> Michael
>>>>>>>>> C. Michael Barton
>>>>>>>>> On Dec 6, 2012, at 12:07 AM, Anna Kratochvílová <kratochanna at gmail.com> wrote:
>>>>>>>>>> Hi Michael,
>>>>>>>>>> On Wed, Dec 5, 2012 at 11:02 PM, Michael Barton <michael.barton at asu.edu> wrote:
>>>>>>>>>>> Any suggestions yet on where the crash I documented in
>>>>>>>>>>> http://trac.osgeo.org/grass/ticket/1736 actually happens in the code so that
>>>>>>>>>>> I can take a look at it and see if there is something fixable for the Mac? I
>>>>>>>>>>> posted what I hope is the relevant debug output to help identify this.
>>>>>>>>>>> While we may need to think about wxPython 2.9, it seems best to first look
>>>>>>>>>>> at what line is actually causing the crash and see if there is a fix or
>>>>>>>>>>> workaround.
>>>>>>>>>> The crash occurs probably in gvl_align_data in gvl_calc.c. The error
>>>>>>>>>> message 'pointer being realloc'd was not allocated' is quite clear,
>>>>>>>>>> however it's not clear why it happens on Mac only. Maybe someone with
>>>>>>>>>> better knowledge of C could understand it more.
>>>>>>>>>> Anna
>>>>>>>>>>> Michael
>>>>>>>>>>> C. Michael Barton
