[GRASS-dev] release planning and no volume display on Mac - Any info on where crash happens?
Michael Barton Michael.Barton at asu.edu
Fri Jan 11 13:33:05 PST 2013
Perhaps Windows and Linux--and earlier versions of OS X--ignore the code.
The header for gvl_calc.c says that the author is Tomas Paudits (February 2004). Does anyone know if he is still around to ask?
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Jan 11, 2013, at 1:18 PM, Helena Mitasova <hmitaso at ncsu.edu>
 wrote:
> On Jan 11, 2013, at 2:48 PM, Anna Kratochvílová wrote:
>> Hi Michael,
>> On Mon, Jan 7, 2013 at 7:57 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>> So I found a change that would make volumes visible again a week ago. Anyone have any thoughts about this? Do we need the function/procedure that sets the memory pointer for volume displays? Or can we simply get rid of it? Is it needed for Linux? Windows? Any thoughts about what happens without it?
>> I can confirm that removing those two lines does no harm for me
>> (Linux). However it's clear that we cannot just leave them out without
>> understanding why they are there. Can anyone (for example Glynn) think
>> of a reason why this code is crashing on Mac and not on Linux (no idea
>> about Windows)?
> I just tested it on Windows 7 with WinGRASS6.4.3RC2 and I am happy to report that it works OK
> - both isosurfaces and crossections.
> However, in the same WinGRASS6.4.3.RC2 there is a problem with the path to cellheader in G3d_read_window,
> so r3.info and g.region rast3d=myvoxel gives an error that the region is invalid.
> Also, I finally got a laptop with MacOSX10.8 and I can confirm that in GRASS6.4.3RC2 binary
> posted Michael isusrfaces crash wxGUI. I will try to compile myself but I expect the result
> to be the same given that it crashed for William as well.
> Helena
>> And why removing of realloc helps?
>> Regards,
>> Anna
>>> Cheers
>>> Michael
>>> C. Michael Barton
>>> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
>>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>>> On Jan 2, 2013, at 11:22 PM, Michael Barton <michael.barton at asu.edu> wrote:
>>>> GREAT NEWS!
>>>> Commenting out both gvl_align_data lines (#684 and #1009) in gvl_calc_c makes this work. Both slices and isosurfaces display and do not crash. I don't know if there would be a problem with larger files or not. But this is finally functional again.
>>>> BUT the command you sent does NOT work. It gives a segmentation fault error:
>>>> m.nviz.image elevation_map=JR_2008_ALL_dem at test3d -a mode=fine resolution_fine=6 color_map=JR_2008_ALL_dem at test3d volume=jr_7408MR_2m_t70 at test3d volume_shading=gouraud volume_resolution=1 volume_position=0,0,20 isosurf_level=1:18.0 isosurf_color_map=jr_7408MR_2m_t70 at test3d isosurf_transparency_value=0 slice=1:x,1:z slice_position=0.000000,1.000000,0.520000,1.000000,0.000000,1.000000,0.250000,0.720000,0.080000,1.000000,0.000000,1.000000 slice_transparency=0,0 position=0.84,0.16 height=356 perspective=20 twist=0 zexag=5.000000 focus=569,593,28 light_position=0.68,0.68,0.80 light_brightness=80 light_ambient=20 light_color=255:255:255 output=jrvoltest format=tif size=798,545
>>>> Loading raster map <JR_2008_ALL_dem at test3d>...
>>>> 100%
>>>> 100%
>>>> Translating colors from raster map <JR_2008_ALL_dem at test3d>...
>>>> 100%
>>>> Loading 3d raster map <jr_7408MR_2m_t70 at test3d>...
>>>> Segmentation fault: 11
>>>> Also, somewhere there is a bug somewhere that is sending progress bar text to the screen for any nviz activity (GRASS_INFO_PERCENT: 0...)
>>>> So now we have some kind of workaround. I don't know if there are any other down sides to bypassing this memory reallocation, but this is a good start on fixing this finally. Thanks Anna and Helena.
>>>> Michael
>>>> C. Michael Barton
>>>> On Jan 2, 2013, at 10:45 PM, Helena Mitasova <hmitaso at ncsu.edu>
>>>> wrote:
>>>>> Michael,
>>>>> what you describe sounds as if you had only one depth layer so let us check first that the 3D region is right.
>>>>> If the 3d region is set to the provided 3d raster given here
>>>>> http://skagit.meas.ncsu.edu/~helena/grasswork/JR_7408MR_2m_t70.asci
>>>>> http://skagit.meas.ncsu.edu/~helena/grasswork/JR_2008_ALL.asci (reference 2d raster)
>>>>> it should look like this
>>>>> GRASS 6.4.3svn (nc_spm_05):~ > g.region -p3
>>>>> projection: 99 (Lambert Conformal Conic)
>>>>> zone:       0
>>>>> datum:      nad83
>>>>> ellipsoid:  a=6378137 es=0.006694380022900787
>>>>> north:      250690
>>>>> south:      249502
>>>>> west:       912791
>>>>> east:       913931
>>>>> top:        64.00000000
>>>>> bottom:     0.00000000
>>>>> nsres:      2
>>>>> nsres3:     2
>>>>> ewres:      2
>>>>> ewres3:     2
>>>>> tbres:      8
>>>>> rows:       594
>>>>> rows3:      594
>>>>> cols:       570
>>>>> cols3:      570
>>>>> depths:     8
>>>>> can you then try to run the following command (please adjust the names of the 2d and 3d rasters to your actual names)
>>>>> m.nviz.image elevation_map=JR_2008_ALL at Baseline_JR -a mode=fine resolution_fine=6 color_map=JR_2008_ALL at Baseline_JR \
>>>>> volume=JR_7408MR_2m_t70 at Baseline_JR volume_shading=gouraud volume_resolution=1 volume_position=0,0,20 isosurf_level=1:18.0 isosurf_color_map=JR_7408MR_2m_t70 at Baseline_JR isosurf_transparency_value=0 slice=1:x,1:z slice_position=0.000000,1.000000,0.520000,1.000000,0.000000,1.000000,0.250000,0.720000,0.080000,1.000000,0.000000,1.000000 slice_transparency=0,0 position=0.84,0.16 height=356 perspective=20 twist=0 zexag=5.000000 focus=569,593,28 \
>>>>> light_position=0.68,0.68,0.80 light_brightness=80 light_ambient=20 light_color=255:255:255 \
>>>>> it should generate an image with isosurfaces and a tilted crossection - it is not quite what I have on the screen, because
>>>>> it apparently uses some default values instead of actual values (e.g. for toggle normal direction and crossection) but it should have some
>>>>> isosurfaces. Let us know whether the command line works and we can go from there.
>>>>> Helena
>>>>> On Jan 3, 2013, at 12:08 AM, Michael Barton wrote:
>>>>>> When I put in values between 15 and 20 I can see the horizontal outline of a rectangle but not the 3D shape of a box. No isosurfaces display. No crash either.
>>>>>> I un-commented line 684 and commented line 1009 in gvl_calc_c to see what happens to slices
>>>>>> /* gvl_align_data(pos, slice->data); */
>>>>>> A horizontal slice displays and I can manipulate it in the X and Y direction. But I cannot manipulate it in the Z direction. Also, a Z dimension slice shows up only as a line. Also, isosurfaces do not display. But there is no crash for either isosurfaces or slices when I comment out this line. On the face of it, a memory issue related to display in the Z dimension is causing a crash. Commenting out calls to gvl_align_data in gvl_calc_c stops the crash and stops display in the Z dimension. There is also something called gvl_calc2_c in this folder. Its code is very similar to gvl_calc_c
>>>>>> I'm guessing that Martin and Helena know the most about the relevant C code for lib/ogsf/*. Glynn may have some insight into this too. Anyone else is welcome to chime in.
>>>>>> FWIW, the last time gvl_calc_c was touched was by Glynn 4 years ago (glynn: Fix char/char* mismatch (merge from trunk, r32757)).
>>>>>> Volume display worked as recently as fall 2011 AFAIK.
>>>>>> Michael
>>>>>> C. Michael Barton
>>>>>> On Jan 2, 2013, at 10:21 AM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
>>>>>>> On Jan 2, 2013, at 1:34 AM, Michael Barton wrote:
>>>>>>>> Testing with GRASS 6.4.3RC2
>>>>>>>> Rem-ing out line 684 in gvl_calc_c
>>>>>>>> /* gvl_align_data(dbuff[i].ndx_new, dbuff[i].new); */
>>>>>>>> prevents crashing. But I don't see an isosurface.
>>>>>>>> Helena,
>>>>>>>> I'm using your test data (jr_7408MR_2m_t70)
>>>>>>>> What is a good value to set for an isosurface to see anything?
>>>>>>> anything between 15 to 20 should work.
>>>>>>> You can move the volume a little bit above the surface to see the entire isosurface
>>>>>>> Here is an example of settings that I have used (the name of the volume raster is slightly different
>>>>>>> but it is the same data).
>>>>>>>> m.nviz.image elevation_map=JR_2008_ALL -a mode=fine resolution_fine=1 color=243:243:243 volume=JR_7408MR_2m volume_shading=gouraud volume_resolution=1 volume_position=0,0,20 isosurf_level=1:17.0 isosurf_color_map=JR_7408MR_2m isosurf_transp_value=0 position=0.11,0.07 height=243 perspective=13 twist=0 zexag=6.000000 focus=569,593,17 light_position=0.26,-0.30,0.61 light_brightness=94 light_ambient=55 light_color=255:255:255 output=nviz_output format=ppm size=798,545
>>>>>>> This volume includes no-data because the original rasters were masked, I think it would be useful to start with a volume without no-data -
>>>>>>> just use r3.null to replace no-data with 0.
>>>>>>> Let me know if it would be useful for me to run same thing in MacOSX 10.6 (I still don't have 10.8 machine quite ready),
>>>>>>> (see the slides 12 and 13 here for the isosurfaces at different levels, I have the isosurfaces colored by year - I don't think I gave you
>>>>>>> that raster, so your isosurfaces should be just a single color).
>>>>>>> http://skagit.meas.ncsu.edu/~helena/publwork/AGU2012lidar6.pptx
>>>>>>> Helena
>>>>>>>> Slices still crash because they still call gvl_align_data. As before, though initially displaying a slice works fine. It only crashes when I try to change something about the slice and it wants to redraw.
>>>>>>>> Michael
>>>>>>>> C. Michael Barton
>>>>>>>> On Jan 1, 2013, at 1:24 PM, Anna Kratochvílová <kratochanna at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hi Michael,
>>>>>>>>> On Tue, Jan 1, 2013 at 8:48 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>>>>>>>> Hi Anna,
>>>>>>>>>> On the slim chance that you are online today, can you tell me where gvl_align_data in gvl_calc.c reside in either the source code or compiled code? I have a bit of down time and thought I'd see what I could find out about the volume display breaking. I don't know C but can selectively rem out some things and see what happens.
>>>>>>>>> It should be here
>>>>>>>>> http://trac.osgeo.org/grass/browser/grass/trunk/lib/ogsf/gvl_calc.c#L685
>>>>>>>>> Also, you could try debugging with QtCreator [1] (as an user-friendly
>>>>>>>>> interface to the debugger), it is quite easy, here [2] is some help
>>>>>>>>> for setting up the project. I don't know what method you would like to
>>>>>>>>> use but this is the easiest I know. I suppose it should work on Mac,
>>>>>>>>> too.
>>>>>>>>> Regards,
>>>>>>>>> Anna
>>>>>>>>> [1] http://qt-project.org/downloads
>>>>>>>>> [2] http://grasswiki.osgeo.org/wiki/Using_QtCreator_for_GRASS_C_development#Debugging
>>>>>>>>>> Thanks
>>>>>>>>>> Michael
>>>>>>>>>> C. Michael Barton
>>>>>>>>>> On Dec 6, 2012, at 12:07 AM, Anna Kratochvílová <kratochanna at gmail.com> wrote:
>>>>>>>>>>> Hi Michael,
>>>>>>>>>>> On Wed, Dec 5, 2012 at 11:02 PM, Michael Barton <michael.barton at asu.edu> wrote:
>>>>>>>>>>>> Any suggestions yet on where the crash I documented in
>>>>>>>>>>>> http://trac.osgeo.org/grass/ticket/1736 actually happens in the code so that
>>>>>>>>>>>> I can take a look at it and see if there is something fixable for the Mac? I
>>>>>>>>>>>> posted what I hope is the relevant debug output to help identify this.
>>>>>>>>>>>> While we may need to think about wxPython 2.9, it seems best to first look
>>>>>>>>>>>> at what line is actually causing the crash and see if there is a fix or
>>>>>>>>>>>> workaround.
>>>>>>>>>>> The crash occurs probably in gvl_align_data in gvl_calc.c. The error
>>>>>>>>>>> message 'pointer being realloc'd was not allocated' is quite clear,
>>>>>>>>>>> however it's not clear why it happens on Mac only. Maybe someone with
>>>>>>>>>>> better knowledge of C could understand it more.
>>>>>>>>>>> Anna
>>>>>>>>>>>> Michael
>>>>>>>>>>>> C. Michael Barton
