[GRASS-dev] [GRASS GIS] #1862: Corrections GRASS 7.0 help files db.connect and v.db.connect
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Jan 25 00:31:28 PST 2013
Hi Markus,
OK, as an example, in db.connect, the 'offending' text is under the
'Parameter' heading. The default driver name and the default database
name should change (marked with >>):
driver=name
Name of database driver
Options: pg, odbc, mysql, ogr, dbf, sqlite
>> Default: sqlite
database=name
Name of database
>> Default: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
schema=name
Database schema
Do not use this option if schemas are not supported by driver/database server
group=string
Default group of database users to which select privilege is granted
Just for my understanding, these parts of the manual page are not in the
html file
(http://svn.osgeo.org/grass/grass/trunk/db/db.connect/db.connect.html)
and I assume they are generated / parsed from the actual code? With no
understanding of the source code (I had a look out of curiosity, but
that was an exercise in futility), I was wondering how/if I could
suggest changes that would actually be more helpful then just mentioning
them like above.
Cheers,
Paulo
On Fri 25 Jan 2013 07:09:56 AM CET, Markus Neteler wrote:
> Hi Paulo,
> not at all. You may post the change suggestions even as email and
> we'll merge them in manually, not too much work in this case.
> I just don't manage to write the better examples myself in this period.
> Thanks,
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130125/d7c8d46f/attachment.html>
