[GRASS-dev] [GRASS GIS] #1862: Corrections GRASS 7.0 help files db.connect and v.db.connect
Markus Metz
markus.metz.giswork at gmail.com
Fri Jan 25 00:50:09 PST 2013
On Fri, Jan 25, 2013 at 9:31 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hi Markus,
> OK, as an example, in db.connect, the 'offending' text is under the
> 'Parameter' heading. The default driver name and the default database name
> should change (marked with >>):
> driver=name
> Name of database driver
> Options: pg, odbc, mysql, ogr, dbf, sqlite
> >> Default: sqlite
> database=name
> Name of database
> >> Default: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> schema=name
> Database schema
> Do not use this option if schemas are not supported by driver/database
> server
> group=string
> Default group of database users to which select privilege is granted
> Just for my understanding, these parts of the manual page are not in the
> html file
> (http://svn.osgeo.org/grass/grass/trunk/db/db.connect/db.connect.html) and
> I
> assume they are generated / parsed from the actual code? With no
> understanding of the source code (I had a look out of curiosity, but that
> was an exercise in futility), I was wondering how/if I could suggest
> changes
> that would actually be more helpful then just mentioning them like above.
I think the demolocation in the source tree needs to be changed to
sqlite, because db.connect and v.db.connect use
db_get_default_*_name().
Markus M
> Cheers,
> Paulo
> On Fri 25 Jan 2013 07:09:56 AM CET, Markus Neteler wrote:
> Hi Paulo,
> not at all. You may post the change suggestions even as email and
> we'll merge them in manually, not too much work in this case.
> I just don't manage to write the better examples myself in this period.
> Thanks,
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
