[GRASS-dev] [GRASS-SVN] r54770 - grass-addons/grass6/raster/r.mess
Paulo van Breugel
p.vanbreugel at gmail.com
Sun Jan 27 05:23:59 PST 2013
Hi Markus,
Thanks for looking into this. It didn't work in first instance, but
after a completely clean install it works, with one caveat. The help
file shows now, but without the parameter info (which supposedly should
be extracted from the script?). I am also getting the following error
message:
Fetching <r.mess> from GRASS-Addons SVN (be patient)...
Compiling...
/usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Script.make:47:
warning: overriding commands for target `install'
/usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Rules.make:99:
warning: ignoring old commands for target `install'
ERROR: G_getenv(): Variable LOCATION_NAME not set
/bin/sh: 1: cannot create
/usr/local/grass6.4.current/grass-6.4.3svn/locale/scriptstrings/r.mess_to_translate.c:
Directory nonexistent
Installing...
/usr/bin/install: cannot stat
`/home/paulo/Data/GRASSdb/latlon/Testing/.tmp/paulo-HP-Z600-Workstation/4248.0/r.mess/man/man1/r.mess.1':
No such file or directory
make: *** [install] Error 1
WARNING: Installation failed, sorry. Please check above error messages.
I tried a few other extensions, and the same happens, so this does not
seem to be something specific to r.mess (but I don't know if it is
something specific to my system?).
Cheers,
Paulo
On 01/27/2013 11:21 AM, Markus Neteler wrote:
> Hi Paulo,
> I tested and had the same problem. The trick is that older r.mess
> installations must be removed first from $HOME/.grass6/addons/
> (or wherever), then it works nicely.
> Hence I have taken liberty to revert this change in SVN... which is
> incompliant anyway with GRASS 6.
> Best
> Markus
> On 1/26/13, svn_grass at osgeo.org <svn_grass at osgeo.org> wrote:
>> Author: pvanbosgeo
>> Date: 2013-01-26 03:49:49 -0800 (Sat, 26 Jan 2013)
>> New Revision: 54770
>> Added:
>> grass-addons/grass6/raster/r.mess/r.mess.html
>> Log:
>> For some reason the manual page is not automatically generated from
>> description.html (i.e., no manual tab in the r.mess window). I therefore
>> added this r.mess.html file with the full manual page so it is available for
>> the user.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130127/90fb6878/attachment.html>
