[GRASS-dev] [GRASS-SVN] r54770 - grass-addons/grass6/raster/r.mess
Paulo van Breugel
p.vanbreugel at gmail.com
Sun Jan 27 14:26:12 PST 2013
Hi Markus,
I am running Ubuntu 12.10. I am not sure what that means, g.extension being
used outside of a GRASS session?
I could perhaps also be related to how I installed grass? Below my set of
.configure - make - make install and some further details (not sure they
are useful info, but adding just in case).
./configure --enable-64bit --prefix=/usr/local/grass6.4.current
--with-sqlite --with-postgres
--with-postgres-libs=/usr/include/postgresql/libpq
--with-postgres-includes=/usr/include/postgresql --with-odbc --with-geos
--with-cairo --with-cxx=yes --with-gdal=/usr/local/gdal1.9/bin/gdal-config
--with-libs=/lib64 --with-python=yes --with-wxwidgets=/usr/bin/wx-config
--with-tcltk-includes=/usr/include/tcl8.5 --with-readline --with-freetype
--with-freetype-includes=/usr/include/freetype2 --enable-largefile
--with-motif --with-motif-includes=/usr/include
--with-proj-share=/usr/share/proj
make
sudo make install
I also created a shortcut in the /usr/bin: sudo ln -s
/usr/local/grass6.4.current/bin/grass64 /usr/bin/grass6.4 + Added a
configuration file in /etc/ld.so with the following line:
/usr/local/grass6.4.current/grass-6.4.3svn/lib.
Your help is much appreciated. I am happy it all runs, so this isn't a
major issue, but it would obviously be good if I could solve this.
On Sun, Jan 27, 2013 at 9:16 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Jan 27, 2013 at 2:23 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
> > Hi Markus,
> > Thanks for looking into this. It didn't work in first instance, but
> after a
> > completely clean install it works,
> (yes, g.extension in GRASS 6 doesn't handle properly the case of
> reinstallation)
> > with one caveat. The help file shows now,
> > but without the parameter info (which supposedly should be extracted from
> > the script?).
> Yes, caused by the error below:
> > I am also getting the following error message:
> > Fetching <r.mess> from GRASS-Addons SVN (be patient)...
> > Compiling...
> > /usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Script.make:47:
> > warning: overriding commands for target `install'
> > ERROR: G_getenv(): Variable LOCATION_NAME not set
> To me it looks like g.extension being used outside of a GRASS session.
> > I tried a few other extensions, and the same happens, so this does not
> seem
> > to be something specific to r.mess
> On Fedora 17 no problem, it installs properly.
> > (but I don't know if it is something specific to my system?).
> Apparently yes: which OS is it?
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130127/0dec4e46/attachment.html>
