[GRASS-dev] g.extension not working on debian - grass 6.4.3svn
Margherita Di Leo
dileomargherita at gmail.com
Mon Jan 28 12:43:24 PST 2013
Hamish,
KUDOS! It works like a charm, tested with addons in C, in python and in
bash.
Thanks A LOT!
madi
On Mon, Jan 28, 2013 at 1:16 PM, Hamish <hamish_b at yahoo.com> wrote:
> Hi,
> It should be fixed now, please svn up & test a bunch.
> Tested with d.barb and v.surf.icw, both from run the build
> dir and after 'make install'. all seemed to be ok.
> I also backported the update to g.manual so that it will work
> with man and html help pages for your addon modules too.
> GRASS> g.manual -m r.stack
> "man g.addonmodule" still doesn't work; $MANPATH overrides
> instead of adding to the path, and we'd have to move
> $ADDONS/docs/man/ to $ADDONS/man/ to get it picked up
> automatically. (one level above an entry in $PATH, or a sibling
> directory of something ending in bin/. see /etc/manpath.config)
> You can get around that with a symlink if you don't mind the
> clutter.
> Hamish
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130128/5e057169/attachment.html>
