[GRASS-dev] [GRASS GIS] #306: hidden tabs are hard to spot in wxGUI module windows
GRASS GIS trac at osgeo.org
Thu Jul 4 01:54:04 PDT 2013
 Reporter:  msieczka     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-develbranch6
 Keywords:  tabs         |    Platform:  All
      Cpu:  All          |
Changes (by wenzeslaus):
  * milestone:  6.4.4 => 7.0.0
Comment:
 There is a new option in settings (''Appearance'' tab) to change the style
 of notebook (tabs) for generated module dialogs (r52927, see an old [http
 ://osgeo-org.1560.x6.nabble.com/command-dialog-notebook-styles-
 td4997929.html announcement on ML]). Some of the styles are using native
 notebook (tabs). Usually, the problem with too many tabs is solved in
 better way than the fancy green notebook solves it.
 Maybe, we need to change the default settings now to the most standard
 system style.
 Minor issue is what to do with icons in the tabs. It seems that is it good
 only for vertical style. Moreover, it is not clear if there are some
 symbols to describe the tabs.
 For GRASS 6 it is wontfix, it is not possible to backport it easily,
 changing milestone to 7.
Ticket URL: <https://trac.osgeo.org/grass/ticket/306#comment:24>
