[GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets column names
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Jul 4 05:23:33 PDT 2013
Hi
I just downloaded the newest GRASS (7) version from svn in order to test the issue.
In the build process I get an error message:
"Errors in:
/data/src/grass70svn/man"
make in the man directory says:
"make[2]: `/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.gmodeler.1' is up to date.
VERSION_NUMBER=7.0.svn /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/tools/g.html2man.py /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.1
/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html:643:0: Error (IndexError('pop from empty list',)): <a href="wxGUI.components.html">wxGUI components</a><br/>
make[2]: *** [/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.1] Error 1
make[2]: Leaving directory `/data/src/grass70svn/man'
make[1]: *** [manpages] Error 2
make[1]: Leaving directory `/data/src/grass70svn/man'
make: *** [default] Error 2"
Any ideas?
Cheers
Stefan
-----Original Message-----
From: grass-dev-bounces at lists.osgeo.org [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of GRASS GIS
Sent: 4. juli 2013 13:25
Subject: Re: [GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets column names
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-trunk
Keywords: d.vect | Platform: Linux
Cpu: x86-64 |
Comment(by annakrat):
Please test again, the column problem should be fixed. Please be more specific about the other problems, include the traceback error.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2012#comment:1>
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
