[GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets column names
Anna Petrášová
kratochanna at gmail.com
Thu Jul 4 05:50:05 PDT 2013
On Thu, Jul 4, 2013 at 2:23 PM, Blumentrath, Stefan <
Stefan.Blumentrath at nina.no> wrote:
> Hi
> I just downloaded the newest GRASS (7) version from svn in order to test
> the issue.
> In the build process I get an error message:
> "Errors in:
> /data/src/grass70svn/man"
> make in the man directory says:
> "make[2]:
> `/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.gmodeler.1'
> is up to date.
> VERSION_NUMBER=7.0.svn
> /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/tools/g.html2man.py/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html
> /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.1
> /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html:643:0:
> Error (IndexError('pop from empty list',)): <a
> href="wxGUI.components.html">wxGUI components</a><br/>
> make[2]: ***
> [/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.1]
> Error 1
> make[2]: Leaving directory `/data/src/grass70svn/man'
> make[1]: *** [manpages] Error 2
> make[1]: Leaving directory `/data/src/grass70svn/man'
> make: *** [default] Error 2"
> Any ideas?
sorry, please try to update and compile again (r57012)
Anna
Cheers
> Stefan
> -----Original Message-----
> From: grass-dev-bounces at lists.osgeo.org [mailto:
> grass-dev-bounces at lists.osgeo.org] On Behalf Of GRASS GIS
> Sent: 4. juli 2013 13:25
> Subject: Re: [GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets
> column names
> Reporter: hamish | Owner: grass-dev@…
> Type: defect | Status: new
> Priority: normal | Milestone: 6.4.4
> Component: wxGUI | Version: svn-trunk
> Keywords: d.vect | Platform: Linux
> Cpu: x86-64 |
> Comment(by annakrat):
> Please test again, the column problem should be fixed. Please be more
> specific about the other problems, include the traceback error.
> Ticket URL: <https://trac.osgeo.org/grass/ticket/2012#comment:1>
> GRASS GIS <http://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130704/e164801a/attachment-0001.html>
