[GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets column names
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Jul 4 06:19:59 PDT 2013
Geat!
Now both compiling and d.vect in the wxGUI work (I mean I can choose the layers from the drop-down list and switch forth and back in the tabs and the layers option remains as I set it)!
Thanks!
Just to make sure that it happened on purpose:
The layers-option "-1" is now neither available in the drop-down list nor the default setting for the layers-option in d.vect...
Stefan
From: Anna Petrášová [mailto:kratochanna at gmail.com]
Sent: 4. juli 2013 14:50
To: Blumentrath, Stefan
Cc: grass-dev at lists.osgeo.org
Subject: Re: [GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets column names
On Thu, Jul 4, 2013 at 2:23 PM, Blumentrath, Stefan <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>> wrote:
Hi
I just downloaded the newest GRASS (7) version from svn in order to test the issue.
In the build process I get an error message:
"Errors in:
/data/src/grass70svn/man"
make in the man directory says:
"make[2]: `/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.gmodeler.1' is up to date.
VERSION_NUMBER=7.0.svn /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/tools/g.html2man.py<http://g.html2man.py> /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.1
/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html:643:0: Error (IndexError('pop from empty list',)): <a href="wxGUI.components.html">wxGUI components</a><br/>
make[2]: *** [/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.1] Error 1
make[2]: Leaving directory `/data/src/grass70svn/man'
make[1]: *** [manpages] Error 2
make[1]: Leaving directory `/data/src/grass70svn/man'
make: *** [default] Error 2"
Any ideas?
sorry, please try to update and compile again (r57012)
Anna
Cheers
Stefan
-----Original Message-----
From: grass-dev-bounces at lists.osgeo.org<mailto:grass-dev-bounces at lists.osgeo.org> [mailto:grass-dev-bounces at lists.osgeo.org<mailto:grass-dev-bounces at lists.osgeo.org>] On Behalf Of GRASS GIS
Sent: 4. juli 2013 13:25
Reporter: hamish | Owner: grass-dev at ...
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-trunk
Keywords: d.vect | Platform: Linux
Cpu: x86-64 |
Comment(by annakrat):
Please test again, the column problem should be fixed. Please be more specific about the other problems, include the traceback error.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2012#comment:1>
grass-dev mailing list
grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130704/02b27e72/attachment.html>
