[GRASS-dev] v.in.ogr fails to import from PostGIS with schema
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri Jul 5 01:02:15 PDT 2013
Dear all
I am reposting this message, because the problem, that I cannot import lines from PostGIS is still present in GRASS 7 svn-revision 57009 (and in 6.4.3svn (older revision) too.)
Do you think this is only due to my PostGIS og GDAL/OGR installation, or shall I file a ticket?
Another (much less important) thing here is, that the status message says:
"Counting polygons for 6125184 features (OGR layer
<n50_2013_utm33n.n50_2013_arealdekke_lines>)..."
although the layer only contains (6125184) lines...
Cheers
Stefan
-----Original Message-----
From: grass-dev-bounces at lists.osgeo.org [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Blumentrath, Stefan
Sent: 31. mai 2013 08:27
To: Markus Neteler; grass-dev at lists.osgeo.org
Subject: Re: [GRASS-dev] v.in.ogr fails to import from PostGIS with schema
Hi Markus
Sorry, good to know. It was HTML indeed.
So here is the problem-description in plain ASCII:
When I try to import a vector map containing (lots of) lines from a certain schema in a PostGIS-database, i get the following error messages:
v.in.ogr dsn="PG:host=myserver dbname=gisdata" layer="n50_2013_utm33n.n50_2013_arealdekke_lines" output="Test"
DBMI-SQLite driver error:
Error in sqlite3_prepare():
unrecognized token: "3insert"
ERROR: Cannot insert new row: insert into Test values ( 3insert into Test
values ( 3, NULL, NULL, NULL, NULL, NULL, NULL, 'FiktivDelelinje',
'1000-01-01 0:00:00', NULL, 101 )
While other formats with the same data work just fine:
ogr2ogr -f SQLite /home/stefan/tmp/N50/n50_2013_arealdekke_lin.sqlite "PG:host=myserver dbname=gisdata" n50_2013_utm33n.n50_2013_arealdekke_lines
v.in.ogr dsn=/home/stefan/tmp/N50/n50_2013_arealdekke_lin.sqlite output="N50_2013_arealdekke_lin"This gave no errors...
Forgot to mention in my earlier post, that also importing polygons from the same PostGIS database (and schema) as the lines works fine:
v.in.ogr dsn="PG:host=myserver dbname=gisdata" layer="n50_2013_utm33n.n50_2013_arealdekke_polygons" output="Test_pol"
Gave no error messages either...
So, maybe it is something with the geometry type?
Cheers
Stefan
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
Sent: 31. mai 2013 00:22
To: Blumentrath, Stefan
Hi Stefan,
you message (HTML?) did not contain the relevant error... see below.
It is better to send in pure ASCII...
Best
Markus
On Thu, May 30, 2013 at 9:51 PM, SBL <Stefan.Blumentrath at nina.no> wrote:
> Hi
> When I try to to import a vector map containing (lots of) lines from a
> I was using GRASS 7 (compiled about a month ago) and PostGIS 2.0.1 /
> PostgreSQL 9.1 on Ubuntu 12.04 LTS Server.
> Looks like something got mixed up in the insert statement. Is that a
> known issue or shall I file a ticket?
> Cheers
> Stefan
> http://osgeo-org.1560.x6.nabble.com/v-in-ogr-fails-to-import-from-Post
> GIS-with-schema-tp5057034.html Sent from the Grass - Dev mailing list
> archive at Nabble.com.
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
