[GRASS-dev] v.in.ogr fails to import from PostGIS with schema
Markus Metz
markus.metz.giswork at gmail.com
Fri Jul 5 01:51:20 PDT 2013
On Fri, Jul 5, 2013 at 10:02 AM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Dear all
> I am reposting this message, because the problem, that I cannot import lines from PostGIS is still present in GRASS 7 svn-revision 57009 (and in 6.4.3svn (older revision) too.)
> Do you think this is only due to my PostGIS og GDAL/OGR installation, or shall I file a ticket?
Please try trunk r57016. If this works for you, the changes should be
backported.
> Another (much less important) thing here is, that the status message says:
> "Counting polygons for 6125184 features (OGR layer
> <n50_2013_utm33n.n50_2013_arealdekke_lines>)..."
> although the layer only contains (6125184) lines...
The module only knows if a layer only contains lines after it went
through all features. In this case the polygon count will be zero.
Unless you use v.in.ogr type=boundary in which case lines will be
converted to boundaries.
Markus M
> Cheers
> Stefan
> -----Original Message-----
> From: grass-dev-bounces at lists.osgeo.org [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Blumentrath, Stefan
> Sent: 31. mai 2013 08:27
> To: Markus Neteler; grass-dev at lists.osgeo.org
> Subject: Re: [GRASS-dev] v.in.ogr fails to import from PostGIS with schema
> Hi Markus
> Sorry, good to know. It was HTML indeed.
> So here is the problem-description in plain ASCII:
> When I try to import a vector map containing (lots of) lines from a certain schema in a PostGIS-database, i get the following error messages:
> v.in.ogr dsn="PG:host=myserver dbname=gisdata" layer="n50_2013_utm33n.n50_2013_arealdekke_lines" output="Test"
> DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> unrecognized token: "3insert"
> ERROR: Cannot insert new row: insert into Test values ( 3insert into Test
> values ( 3, NULL, NULL, NULL, NULL, NULL, NULL, 'FiktivDelelinje',
> '1000-01-01 0:00:00', NULL, 101 )
> While other formats with the same data work just fine:
> ogr2ogr -f SQLite /home/stefan/tmp/N50/n50_2013_arealdekke_lin.sqlite "PG:host=myserver dbname=gisdata" n50_2013_utm33n.n50_2013_arealdekke_lines
> v.in.ogr dsn=/home/stefan/tmp/N50/n50_2013_arealdekke_lin.sqlite output="N50_2013_arealdekke_lin"This gave no errors...
> Forgot to mention in my earlier post, that also importing polygons from the same PostGIS database (and schema) as the lines works fine:
> v.in.ogr dsn="PG:host=myserver dbname=gisdata" layer="n50_2013_utm33n.n50_2013_arealdekke_polygons" output="Test_pol"
> Gave no error messages either...
> So, maybe it is something with the geometry type?
> Cheers
> Stefan
> From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
> Sent: 31. mai 2013 00:22
> To: Blumentrath, Stefan
> Hi Stefan,
> you message (HTML?) did not contain the relevant error... see below.
> It is better to send in pure ASCII...
> Best
> Markus
> On Thu, May 30, 2013 at 9:51 PM, SBL <Stefan.Blumentrath at nina.no> wrote:
>> Hi
>> When I try to to import a vector map containing (lots of) lines from a
>> I was using GRASS 7 (compiled about a month ago) and PostGIS 2.0.1 /
>> PostgreSQL 9.1 on Ubuntu 12.04 LTS Server.
>> Looks like something got mixed up in the insert statement. Is that a
>> known issue or shall I file a ticket?
>> Cheers
>> Stefan
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/v-in-ogr-fails-to-import-from-Post
>> GIS-with-schema-tp5057034.html Sent from the Grass - Dev mailing list
>> archive at Nabble.com.
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
