[GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets column names
trac at osgeo.org
Mon Jul 8 02:36:54 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: d.vect
Platform: Linux | Cpu: x86-64
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:2 hamish]:
> tested in trunk, now remembers size_col and rotation_column. thanks.
drop down menu and no-db issues also seem to be fixed.
so I am closing this ticket as fixed
> during testing it's still printing a traceback error to the terminal
though:
> (wxgui.py:3206): Pango-CRITICAL **: pango_layout_get_cursor_pos:
assertion `index >= 0 && index <= layout->length' failed
Usually, this is harmless. It's not easy to fix this, so if you consider
this as a problem open a new ticket (with minor priority).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2012#comment:3>
