[GRASS-dev] [GRASS GIS] #2023: r.li.edgedensity
trac at osgeo.org
Mon Jul 8 03:24:50 PDT 2013
Reporter: matmar | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Raster | Version: unspecified
Keywords: r.li.edgedensity | Platform: Linux
Cpu: x86-64 |
r.li.edgedensity doesn't work using a configuration file (generated with
r.li.setup) with a vector map to overlay. Attached you can find the
generated configuration file.
The r.li.edgedensity error is:
GRASS 6.4.3svn (WGS_84):~ > r.li.edgedensity map=globcover conf=landscape
output=edge_den_map --o
ERROR: Program error, worker() toReceive.type=-1451052184
Segmentation fault (core dumped)
Thanks, Matteo
Ticket URL: <http://trac.osgeo.org/grass/ticket/2023>
