[GRASS-dev] [GRASS GIS] #2023: r.li.edgedensity
trac at osgeo.org
Tue Jul 9 02:50:41 PDT 2013
Reporter: matmar | Owner: matmar
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.3
Component: Raster | Version: svn-releasebranch64
Keywords: r.li.edgedensity | Platform: Linux
Cpu: x86-64 |
Comment(by matmar):
(sorry for the cc mishap)
I have retried with a smaller region, still failing:
GRASS 6.4.3svn (WGS_84):~ > g.region -a res=0:10 -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 65S
west: 180W
east: 180E
nsres: 0:10
ewres: 0:10
rows: 930
cols: 2160
cells: 2008800
GRASS 6.4.3svn (WGS_84):~ > r.li.edgedensity map=globcover conf=conf
output=edge_den_map --o
ERROR: Segmentation fault (core dumped)
Program error, worker() toReceive.type=-729328792
ERROR: Program error, worker() toReceive.type=-729328792
GRASS 6.4.3svn (WGS_84):~ > cat /home/matteo/.r.li/history/conf
SAMPLINGFRAME 0|0|1|1
I wonder if the failure is related to ticket #2024 (incomplete r.li
configuration file, the "MASKEDOVERLAYAREA" entries are missing)?
Restoring the conf file as it should be, it still fails (here two
subsequent runs):
GRASS 6.4.3svn (WGS_84):~/.r.li > r.li.edgedensity map=globcover conf=conf
ERROR: Program error, worker() toReceive.type=97579880
ERROR: Program error, worker() toReceive.type=684966760
Ticket URL: <http://trac.osgeo.org/grass/ticket/2023#comment:8>
