[GRASS-dev] [GRASS GIS] #2024: r.li.setup
GRASS GIS trac at osgeo.org
Mon Jul 8 03:35:29 PDT 2013
#2024: r.li.setup
 Reporter:  matmar      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.4
Component:  Raster      |     Version:  svn-releasebranch64
 Keywords:  r.li.setup  |    Platform:  Linux
      Cpu:  x86-64      |
 I've noticed a difference between the configuration file I generated 3
 weeks ago using vector map to overlay with the one I've just generated
 (same procedure, again using vector map to overlay). In detail, the second
 seems almost empty, without any specified regions.
 I've upgraded grass a couple of times between the two configuration files.
 I've attached the two files (old and new).
 Thanks, Matteo
Ticket URL: <http://trac.osgeo.org/grass/ticket/2024>
