Hi, 2013/7/9 Maris Nartiss <maris.gis at gmail.com>: > Current situation that wxgui fails with cryptic error is also not a > solution. If you consider compatibility with 2.9 to not easy solvable, > is it possible to enforce wxpython <2.9 then? Or make it fail with > "2.8 required" error message? +1 for fail message. Martin
