[GRASS-dev] GRASS 6.4.3 release planning
Maris Nartiss
maris.gis at gmail.com
Tue Jul 9 05:58:06 PDT 2013
Current situation that wxgui fails with cryptic error is also not a
solution. If you consider compatibility with 2.9 to not easy solvable,
is it possible to enforce wxpython <2.9 then? Or make it fail with
"2.8 required" error message?
With r54916 and r51052 at least wxgui came up and I was able to
display a map. No serious testing tough as I just wanted to see if
#1893 is fixed.
Maris.
2013/7/9 Anna Petrášová <kratochanna at gmail.com>:
> On Tue, Jul 9, 2013 at 2:29 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Sorry, Markus, to interrupt you.
>> Don't release without backporting r51052 as 6.4.3 g.gui fails to start
>> with wxpython 2.9.1
>> http://trac.osgeo.org/grass/changeset/51052
> This is not the only change which has to be done to make it work with
> wxpython 2.9. There are quite a lot of them and not all problems are fixed
> in grass 7 yet. I thought we agreed on leaving this for next version. Or?
> If you consider this important, I can backport the fixes but I cannot be
> sure I won't break something.
> Anna
>> Maris.
>> 2013/7/9 Markus Neteler <neteler at osgeo.org>:
>> > (back to this thread)
>> > On Tue, Jul 9, 2013 at 5:28 AM, Helena Mitasova <hmitaso at ncsu.edu>
>> > wrote:
>> >> I am happy to report that the expressions with || now work on windows
>> >> from
>> >> command console when quotes are used.
>> >> Thank you Anna and Glynn for solving this long standing problem for
>> >> wingrass users,
>> >> Helena
>> > Great! At this point time to release RC4!
>> > Markus
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
