[GRASS-dev] [GRASS GIS] #2029: raster legend on discrete maps not graduated
GRASS GIS trac at osgeo.org
Tue Jul 9 13:52:35 PDT 2013
 Reporter:  timmie       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.4
Component:  Raster       |     Version:  unspecified
 Keywords:  d.legend     |    Platform:  Unspecified
      Cpu:  Unspecified  |
Changes (by hamish):
  * keywords:  => d.legend
Comment:
 How many categories in the final image?
 If there are more categories than there are vertical pixels to display
 them in, d.legend automatically changes into smooth gradient mode; it
 issues you a warning telling you that it did it in that case.
 the various thin=, lines=, and use= options can be used to reduce the
 number of categories to something that will fit on the screen. Also you
 should check that the map being used is a CELL map, not a FCELL or DCELL.
 beyond that, I'd need more information to go on about your raster.
 (r.info, screenshots, exact CLI commands to reproduce, xmon or wxGUI, ...)
 regards,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2029#comment:1>
