[GRASS-dev] [GRASS GIS] #2029: raster legend on discrete maps not graduated
trac at osgeo.org
Tue Jul 9 15:55:56 PDT 2013
Reporter: timmie | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: unspecified
Keywords: d.legend | Platform: Unspecified
Cpu: Unspecified |
Comment(by timmie):
Replying to [comment:1 hamish]:
> How many categories in the final image?
5-15 categories.
> If there are more categories than there are vertical pixels to display
them in, d.legend automatically changes into smooth gradient mode; it
issues you a warning telling you that it did it in that case.
I did not see this.
Just a gradient legend with the category breaks as legend labels.
> the various thin=, lines=, and use= options can be used to reduce the
number of categories to something that will fit on the screen. Also you
should check that the map being used is a CELL map, not a FCELL or DCELL.
It's DCELL.
> beyond that, I'd need more information to go on about your raster.
(r.info, screenshots, exact CLI commands to reproduce, xmon or wxGUI, ...)
r.info map=landcover_zones at land
| Layer: landcover_zon Date: Fri Apr 05 11:45:37 2013 |
| Mapset: land Login of Creator: timmie
| DataBase: /home/timmie/gis/grassdata
| Title: Reclass of landcover |
| Timestamp: none
| Type of Map: reclass Number of Categories: 0
| Data Type: CELL
| Rows: 12076
| Columns: 16879
| Total Cells: 203830804
| Projection: Mercator
| N: 6698600 S: 6491000 Res: 100
| E: 2205800 W: 0517900 Res: 100
| Range of data: min = 2099 max = 3000
| Data Source:
| Reclassified map based on:
| Map [landcover_base at land] in mapse |
| Data Description:
| Comments:
| generated by r.reclass
| r.reclass ... |
Ticket URL: <http://trac.osgeo.org/grass/ticket/2029#comment:2>
