[GRASS-dev] [GRASS GIS] #793: Provide breakline (fault line) support for surface interpolation modules
GRASS GIS trac at osgeo.org
Thu Jul 11 17:17:58 PDT 2013
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:  breaklines   |    Platform:  All
      Cpu:  All          |
Changes (by hamish):
  * keywords:  => breaklines
  * platform:  Unspecified => All
  * version:  unspecified => svn-trunk
  * cpu:  Unspecified => All
Comment:
 see also Alexander Muriy's v.triangle addon module,
   http://grasswiki.osgeo.org/wiki/TIN_with_breaklines
 Hamish wrote:
 > try v.surf.icw from addons. [...] it is very computationally expensive
 > so number of starting points should be kept low.
 note the new version isn't quite as expensive as the old, and now supports
 multi-processing. Probably should still be limited to less than a few
 hundred input points though.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/793#comment:3>
