[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
GRASS GIS trac at osgeo.org
Fri Jul 12 05:18:14 PDT 2013
 Reporter:  martinl           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  blocker           |   Milestone:  7.0.0
Component:  Database          |     Version:  unspecified
 Keywords:  sqlite, wingrass  |    Platform:  MSWindows 2K
      Cpu:  Unspecified       |
Comment(by mlennert):
 Replying to [comment:39 mlennert]:
 > Replying to [comment:38 neteler]:
 > > Replying to [comment:34 hamish]:
 > > > Replying to [comment:33 neteler]:
 > > > > I have tried with r56943 on Windows8, still failing:
 > > > > GRASS 7.0.svn> db.describe overpasses
 > > > is the overpass vector map in the current mapset? You may be seeing
 the effect of the db.* modules only working for databases linked from maps
 in the current mapset, unless you explicitly set database= to the real
 path, not the default which may expand $MAPSET to the current mapset, not
 the other mapset's dir name.
 > > In fact it was in a different mapset (PERMANENT). But it should not
 hang
 > > (instead it should report that the table was not found in the current
 mapset).
 > Does it really hand, or does it fail and give back the prompt after the
 error message ?
 s/hand/hang
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:40>
