[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
trac at osgeo.org
Fri Jul 12 05:17:37 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Database | Version: unspecified
Keywords: sqlite, wingrass | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:38 neteler]:
> Replying to [comment:34 hamish]:
> > Replying to [comment:33 neteler]:
> > > I have tried with r56943 on Windows8, still failing:
> > > GRASS 7.0.svn> db.describe overpasses
> > is the overpass vector map in the current mapset? You may be seeing
the effect of the db.* modules only working for databases linked from maps
in the current mapset, unless you explicitly set database= to the real
path, not the default which may expand $MAPSET to the current mapset, not
the other mapset's dir name.
> In fact it was in a different mapset (PERMANENT). But it should not hang
> (instead it should report that the table was not found in the current
mapset).
Does it really hand, or does it fail and give back the prompt after the
error message ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:39>
