[GRASS-dev] Python handling in winGRASS7 [was: Re: GRASS GIS 7 tech-preview release preparations]
Glynn Clements
glynn at gclements.plus.com
Fri Jul 26 11:09:22 PDT 2013
Moritz Lennert wrote:
> - Another issue is how to make it possible in windows to launch modules
> that are Python scripts by simply calling their module name, without .py
> extension. At this stage, in a fresh installation of GRASS7 on WinXP, I
> can launch (and successfully execute) python scripts from the wxGUI menu
> or the wxGUI command console, but not from the windows terminal.
> However, calling a script from a script (e.g. v.db.dropcolumn called
> from v.db.renamecolumn) does not work.
To execute scripts without providing an extension, PATHEXT must
include ".PY".
