[GRASS-dev] GRASS 7 r.neighbours average method giving incorrect value
Glynn Clements
glynn at gclements.plus.com
Sat Jul 13 04:37:02 PDT 2013
Markus Metz wrote:
> I would rather have DCELL output all the times, maybe keep the maptype
> for min, max?
Retaining the type for mode, sum and range would also make sense, as
the result will always be an integer for integer inputs.
For diversity, the result is always an integer even for floating-point
inputs.
For average, median, variance, standard deviation and interspersion,
the output should always be floating-point (although I'm not entirely
certain about median).
